Forum >Cant connect ESP32-S3 AI Camera to wifi :-(
userHead psypol 2025-03-13 05:24:55 2601 Views15 Replies
i can see the lisr of available wifi networks in serial monitor.
then i try to connect to my home wifi in 2.4g but it wont work.
i also tried to connect to a phone hotspot just next to the module. (even without any security.. no password)
the monitors tells me all the time the following :
Starting WiFi connection...
Scanning for WiFi networks...
Available Networks:
1: Redmi (Signal: -24 dBm) (Open)
Available Networks:
...[  5730][W][STA.cpp:137] _onStaArduinoEvent(): Reason: 2 - AUTH_EXPIRE
[  5731][D][STA.cpp:155] _onStaArduinoEvent(): WiFi Reconnect Running
[  5732][W][STA.cpp:541] disconnect(): STA already disconnected.
..[  6752][W][STA.cpp:137] _onStaArduinoEvent(): Reason: 2 - AUTH_EXPIRE
[  6753][D][STA.cpp:158] _onStaArduinoEvent(): WiFi AutoReconnect Running
[  6754][W][STA.cpp:541] disconnect(): STA already disconnected.
...[  7824][W][STA.cpp:137] _onStaArduinoEvent(): Reason: 2 - AUTH_EXPIRE
Is there anything im doing wrong, im basically doing the wifi connection as in the video transmission example :
https://wiki.dfrobot.com/SKU_DFR1154_ESP32_S3_AI_CAM#target_7
or more verbose helped by chat GPT but doing the same.
Any ideas ?
2025-08-01 05:04:13
i can even confirm that a script which scans available WIFI network sees my wifi 2.4 network with best signal
but no chance connecting
userHeadPic psypol
2025-08-01 04:53:46
up. still unable to connect to any wifi
the module works with 5.1 Obtain ambient light data
then i use ALL exact configuration steps as the tutorial shown in this video :
https://www.youtube.com/watch?v=_q_IhaMd8Rs …
WHAT CAN I DO ???
userHeadPic psypol
2025-08-01 04:52:49
up. still unable to connect after retrying..
then i use the exact configuration steps as the tutorial shown in this video :
WHAT CAN I DO ???
userHeadPic psypol
2025-05-02 16:47:35
Same thing is happening for me.  It connected perfectly a few times yesterday when I tested it for the first time.  Today it will not connect at all - I've tried two different routers.  Grrr.  Pleas help @dfrobotteam!
userHeadPic ponsonbysmythe
ponsonbysmythe wrote:
Update.  I found a mention of this fix for ESP32S3 WiFi connection problems in another forum and it worked for me.  It will reduce the current used by the ESP when trying to connect. It goes on every time for me now.  Add the following line after the WiFi(begin) line:
WiFi.setTxPower(WIFI_POWER_2dBm);
2025-05-02 21:18:55
2025-04-10 14:09:29
up
userHeadPic psypol
2025-03-27 15:13:10
up
userHeadPic psypol
2025-03-25 00:06:10
up. device in the box taking dust since the attempt.
frustrated.
userHeadPic psypol
2025-03-22 22:46:13
Up
userHeadPic psypol
2025-03-19 21:39:55
up!
dear @dfrobotteam, maybe you have a solution for this ?
maybe a firmware update or something.
basically i'm happy to not be the only one in that case but it makes the device pretty useless for all of us.
ps: please block this spammer
Regards
userHeadPic psypol
psypol wrote:
also i dont want to be forced to have router on channel1 and 802.11w management frame protection OFF to include the device in my network (see Lupin's hint in thread).
2025-03-20 18:58:50
2025-03-18 09:40:10
My ESP32-S3 also experienced a situation where it couldn't connect to the router. After I set the router's channel to 1 and disabled the 802.11w management frame protection, it was able to connect normally.
userHeadPic erhahaha
2025-03-16 15:30:00
I have done some more testing and can confirm that I can establish the connection (as a station to the access point) with WLAN channel less than 11 (with and without password). But the connection doesn't seem stable! Once the connection and URL are displayed in the serial monitor, access in the browser (or via CURL) isn't possible. Further tests have shown that the WLAN connection is interrupted (at different times). When the ESP is operated as an access point, the WLAN connections are more stable.
userHeadPic Lupin
2025-03-15 23:17:54
It is the same issue for me, too! I have tried to connect to different Wi-Fi 2.4G - no success.
userHeadPic Peter.Usov
2025-03-15 00:11:11
Same issue for me! I followed all steps on Wiki (https://wiki.dfrobot.com/SKU_DFR1154_ESP32_S3_AI_CAM) and tried with different AP's (Router and iPhone Hotspot) … the only output on serial is: WiFi connecting ………..
userHeadPic Lupin
