Forum >What expansion boards does UNIHIKER K10 support?
userHead Tonny12138 2025-03-14 17:26:16 699 Views1 Replies
2025-03-14 17:26:27
UNIHIKER K10 has the same edge connector layout as the micro:bit, so it is compatible with most micro:bit expansion boards. You can refer to this list to see the supported expansion boards: Expansion board Compatible list.
userHeadPic Tonny12138
