Forum >Problem with DFR0850 Arduino POE Ethernet Shield W5500
TroubleshootingArduino
userHead 1WcGrW 2025-03-18 16:38:29 349 Views6 Replies
I'am trying to use the DFR0850 POE shield with an Arduino Uno R3 board.
My Arduino IDE is in version 1.8.19.
I downloaded and installed the right library from the this website.
I try the following program, provided on the site too.
I removed the E-RST jumper.
I connected shield to a non-POE switch, to a POE switch with the same result.
The Ethernet switch connects to a laptop whose address is 192.168.1.254.
I have try with 2 different shields purchased.
The result is always the same :
“server is at 0.0.0.0”
Thank for your help.
 Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
#define SS     10U    //W5500 CS
#define RST    11U    //W5500 RST
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
 pinMode(SS, OUTPUT);
 pinMode(RST, OUTPUT);
 digitalWrite(SS, LOW);
 digitalWrite(RST,HIGH);  //Reset this module
 delay(200);
   digitalWrite(RST,LOW);
 delay(200);
delay(200);
 // Open serial communications and wait for port to open:
 Serial.begin(19200);
 //while (!Serial) {
 //  ; // wait for serial port to connect. Needed for Leonardo only
 // start the Ethernet connection and the server:
 Ethernet.begin(mac, ip);
 server.begin();
 Serial.println(" ");
 Serial.print("server is at ");
 Serial.println(Ethernet.localIP());
 // listen for incoming clients
 EthernetClient client = server.available();
 if (client) {
   //Serial.println("new client");
   // an http request ends with a blank line
   boolean currentLineIsBlank = true;
   while (client.connected()) {
     if (client.available()) {
       char c = client.read();
       Serial.write(c);
       // if you've gotten to the end of the line (received a newline
       // character) and the line is blank, the http request has ended,
       // so you can send a reply
       if (c == '\n' && currentLineIsBlank) {
         // send a standard http response header
         client.println("HTTP/1.1 200 OK");
         client.println("Content-Type: text/html");
         client.println("Connection: close");// the connection will be closed after completion of the response
         client.println("Refresh: 5");  // refresh the page automatically every 5 sec
         client.println();
         client.println("<!DOCTYPE HTML>");
         client.println("<html>");
         // output the value of each analog input pin
         for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
           int sensorReading = analogRead(analogChannel);
           client.print("analog input ");
           client.print(analogChannel);
           client.print(" is ");
           client.print(sensorReading);
           client.println("<br />");
         client.println("</html>");
         break;
       if (c == '\n') {
         // you're starting a new line
       else if (c != '\r') {
         // you've gotten a character on the current line
         currentLineIsBlank = false;
   // give the web browser time to receive the data
   delay(1);
   // close the connection:
   client.stop();
   Serial.println("client disconnected");
2025-03-21 14:49:18
Be careful with the use of a shield, ICSP connector is needed, MISO, MOSI and SCK come from there.
Fred
userHeadPic 1WcGrW
2025-03-19 23:24:59
It seems working now !
It remains 2 warnings :
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\socket.cpp: In function 'void flush(SOCKET)':
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\socket.cpp:316:19: warning: unused parameter 's' [-Wunused-parameter]
void flush(SOCKET s) {
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\socket.cpp: In function 'uint16_t igmpsend(SOCKET, const uint8_t*, uint16_t)':
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\socket.cpp:322:11: warning: variable 'status' set but not used [-Wunused-but-set-variable]
  uint8_t status=0;
thank you all for your help.
userHeadPic 1WcGrW
2025-03-19 23:15:57
socket.cpp file belongs to the old version :-(
It remains only 2 warnings now :-)
  uint8_t status=0;
userHeadPic 1WcGrW
2025-03-19 23:08:07
I had not updated the right repertoire with the new library, now I have compilation errors.
Here are the the first 2:
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\socket.cpp:56:46: error: no 'void EthernetClass::socketPortRand(uint16_t)' member function declared in class 'EthernetClass'
void EthernetClass::socketPortRand(uint16_t n)
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\socket.cpp:63:67: error: no 'uint8_t EthernetClass::socketBegin(uint8_t, uint16_t)' member function declared in class 'EthernetClass'
uint8_t EthernetClass::socketBegin(uint8_t protocol, uint16_t port)
userHeadPic 1WcGrW
2025-03-19 00:01:12
I tested the SPI bus by looping pins 11 and 12, so the problem comes from the Ethernet library
userHeadPic 1WcGrW
2025-03-18 22:37:04
How can I already test the communication SPI?
userHeadPic 1WcGrW
