Forum >Can I use one speaker with DFPlayer Pro?
userHead moose 2025-03-20 03:44:41 856 Views3 Replies
I just got the DFPlayer Pro. I'm new to electronics and microcontrollers. I was wondering if a single speaker could be used instead of two for stereo. If so, how would I do that? I assume using either L+ and R- or vice versa. I will be using an 8 ohm 3 watt speaker.
2025-03-21 16:43:12
Yes you can use only one speaker. For example L+ and L- or R+ and R-.
userHeadPic Lupin
Lupin wrote:
I would recommend to be careful with 8 ohms and 3 watt! WIKI says: Suggest using a 4 ohms 3 watt speaker! I am not 100% sure but an external amplifier can help.
2025-03-21 16:50:11
moose wrote:
Thank you!!
I will look into the speaker issue next.
I appreciate your help!
2025-04-09 07:50:04
