Forum >IoT Router Board Mini + Compute Module 5
userHead Screwface2591 2025-03-21 18:51:11 971 Views2 Replies
Also it is not mentionned to be compatible and wiki page does not get updates, I tried to run the IoT Router Board Mini with a Compute Module 5.
I managed to generate a custom image starting the working Raspberry Pi5 version and added the missing modules for the RTL8111 chip.
Now I have a fully booting image and both NICs are detected. But for a reason I don't understand, I can not get a PC to communicate with the router.
Eth0 has 192.168.1.1 as a static IP address, but the attached computer seems not to get an IP allocated from DHCP server. Even if I set the computer's IP address to 192.168.1.2 manually, I can not get poth to communicate or ping.
There is no public schematic of the board so I can not troubleshoot. Looking at the CM4 and CM5 differences regarding pinout, I noticed the following pin functions changes :  Fan_Tacho (pin 16) replaces Ethernet_SYNC_IN and Fan_PWM (pin 19) replaces Ethernet_nLED1.
I don't know if those modifications can explain the communication issue I'm facing.
The same image works fine on Raspberry Pi5.
If anyone have suggestions, I'm all ears!
2025-03-24 16:39:24
I made one more test trying the Raspberry OS lite with the carrier board. I managed to boot and connect to network, apt update and upgrade, with both ethernet ports.
This brings me to the fact that hardware part is working fine, with no incompatibility between the router mini board and the CM5. So I guess I'm only facing SW issues. Still investigating…
userHeadPic Screwface2591
Screwface2591 wrote:
If you are interested, I got it working. An IRQ to remove in the device tree. This is an early post, I have to use my port to see if reliable, and understand why I needed to remove this IRQ which is not present in Raspberry Pi5. I think I'll post on OpenWRT forum rather than here, to share more widely.
2025-04-10 18:34:07
