Forum >Unihiker K10 AI prgramming using Arduino libraries
General UNIHIKER
userHead Ralph.Yamamoto 2025-03-25 13:04:16 1054 Views2 Replies
It appears that it is possible to use the Arduino IDE to program the Unihiker K10 by using the \Mind+\Arduino\hardware\dfrobot\esp32s3\libraries but I noticed that not all of the #include files used in the examples are in that path.  Is there documentation on the correct method of installing the required libraries for the AI examples?
2025-03-30 21:45:55
Hi, the UNIHIKER K10 SDK for Arduino IDE is under development, and is currently recommended to be used in conjunction with MindPlus, I'll let you know when the link is available!
userHeadPic Xiao
