Forum >3.3 volts on the firebeetle esp32 2 C6 - DFR1075
userHead Alexandre.Leviev 2025-03-25 20:44:49 708 Views0 Replies
A lot of firebeetle boards have an enable pin that you can ground to deactivate the on-board voltage converter and directly input 3.3 volts via the 3.3 volts pin. I am using the firebeetle esp32 2 C6. It doesn't have such a pin. Can I still use it with 3.3 volts ? Will I damage the on-board HM6245 ?
Best regards,
Alex L
