Forum >BLE Sensor Beacon and RFID/NFC type tags
Can the BLE Sensor Beacon be used by itself or with other hardware to read tags of some sort to indicate location of that tag in a warehouse. Say tag #1234 read by beacon #5, means it is xx position. Using bt result to go into open spreadsheet on laptop with tag reading and an ID of beacon. Read distance is only up to 50mm.
Charles
2025-04-18 10:25:55
Yeez_B
You can understand that the BLE Sensor Beacon is a very simple MCU dev board.
Its only function is to receive data from digital/analogue/I2C sensors and transmit it out via Bluetooth BLE.
Unfortunately it doesn't support tag reading.
