Forum >SD Card librabry MEGA Sensor Shield V2.4
TroubleshootingArduino
userHead Peter.Pan 2025-03-29 17:20:04 687 Views0 Replies
How can I use the Arduino SD library with the MEGA Sensor Shield V2.4 on a DFRobot Mega 2560? What SDCARD_SS_PIN should be used? the wiki is very lacking sadly :(
I tried chipSelect = 4, 8, 10, 53 in the SD CardInfo sketch but each gives:
Initializing SD card...initialization failed. Things to check:
* is a card inserted?
* is your wiring correct?
* did you change the chipSelect pin to match your shield or module?
