Forum >DFR0781 BT401 How to enter AT mode?
userHead Per.Svensson 2025-04-02 05:11:05 1488 Views4 Replies
The default mode for BT401 is transparent pass through mode.
In the documentation there is not mentioned how to leave transparent mode and enter AT-mode.
How is this done from the serial UART?
The normal way for modems is to enter +++ and wait for OK.
This does not work for me.
Pleeease give me instructions. I have run out of ideas!! :(
/Per
2025-04-03 00:50:17
Thanks for the answer. But there are still some things I cant understand.
1. How can the modem recognise a AT-command in transparent mode?
  There is no way to distinguish it from any other text-string on its way to the receiver.
  The serial stream could very well contain AT+..…
2. I have tried all sort of AT-commands and none of them are accepted.
 They are simply sent transparently to the receiver the
3 The modem listen to a few AT-commands just after Reset. But after a couple of seconds it enters transparent mode. Please explain the start up procedure.
Sorry to say. There is certainly something I have missed!
/Per
userHeadPic
 Per.Svensson
userHeadPic Per.Svensson
2025-04-03 00:47:35
/Per
2025-04-02 09:14:16
BT401 does not need to send a command to enter AT mode, you only need to send the corresponding AT command can be, but pay attention to the '\r\n' after the AT command.
userHeadPic erhahaha
Per.Svensson wrote:
Couldyou please elaborate your answer a little bit?
2025-04-05 05:30:46
