Forum >DFR0151 RTC not keeping time
userHead Bart.Woodstrup 2025-04-06 00:35:56 1034 Views1 Replies
I have a Gravity DFR0151 RTC that I have connected to a DFRobot Nano which is on a I/O Nano Shield. I am able to set the time and record the time onto a datalogger, however, after a period of time the clock resets itself.
I have new battery. I have been switching the #define updata_flag 0 //1 updata time,0 only show time
Is the DFR0151 compatible with the Nano? Is the problem that it is getting 3.3V but needs 5V?
I don't understand why it works sometimes and not others.
Any help appreciated.
2025-04-06 01:08:23
This is the RTC part of my code:
//Datalogger
#define SPIN 6  //Connect to the module Pin S, trigger to save files at low level
uint16_t i = 0;
//RTC
#include <DFRobot_DS1307.h>
//Note: #define updata_flag 0 //1 updata time,0 only show time
DFRobot_DS1307 DS1307;
 //Datalogger
 Serial.begin(115200);
 delay(2000);  //To aviod data lost, delay a period of time to wait for the module to start
 pinMode(SPIN, OUTPUT);
 digitalWrite(SPIN, HIGH);
 //RTC
 //Serial.begin(115200);
 // Initialize sensor
 while (!(DS1307.begin())) {
   Serial.println("Communication with device failed, please check connection");
   delay(3000);
 DS1307.start();
 DS1307.setSqwPinMode(DS1307.eSquareWave_1Hz);
 Serial.print("Time");
 Serial.print(",");
 Serial.print("Date");
 Serial.print(",");
 delay(100);
 Serial.print(DS1307.getTypeTime(DS1307.eHR));
 Serial.print(":");
 Serial.print(DS1307.getTypeTime(DS1307.eMIN));
 Serial.print(":");
 Serial.print(DS1307.getTypeTime(DS1307.eSEC));
 Serial.print(",");
 Serial.print(DS1307.getTypeTime(DS1307.eMTH));
 Serial.print("/");
 Serial.print(DS1307.getTypeTime(DS1307.eDATE));
 Serial.print("/");
 Serial.print(DS1307.getTypeTime(DS1307.eYR));
 Serial.print(",");
 delay(1000);
userHeadPic Bart.Woodstrup
