Forum >BME280 Not Detected on FireBeetle ESP32-E via I2C
userHead kapjez.kapjez 2025-04-18 10:54:20 371 Views3 Replies
Hi everyone,
I'm currently using the Gravity: I2C BME280 Environmental Sensor with a FireBeetle ESP32-E board. I connected the sensor via I2C (SDA to D2, SCL to D1, using 3.3V and GND), but when I run an I2C scanner, it doesn't detect any address.
I also tried the sample code from the DFRobot wiki, but still no luck – just getting “sensor not found” in the serial monitor.
Has anyone run into this before? Any suggestions on how to troubleshoot this?
Thanks in advance!
pkph3mxoheihjodnd
2025-05-15 15:01:44
It could be a wiring issue or sensor address mismatch. Double-check your SDA/SCL pins (FireBeetle uses D1 = GPIO22, D2 = GPIO21 by default), and make sure pull-up resistors are in Doodle Jump. Also, try running the I2C scanner with different addresses like 0x76 or 0x77—the BME280 can use either depending on its configuration.
userHeadPic Bryon.Pearson
2025-04-20 16:22:03
If your sensor is alright, you can also follow this project. It is regarding Uploading BME280 Sensor Data to ThingSpeak Using ESP32. It will show you how to connect a BME280 sensor to an ESP32 to read temperature, humidity, and atmospheric pressure data.
https://www.pcbway.com/project/shareproject/Uploading_BME280_Sensor_Data_to_ThingSpeak_Using_ESP32_a2df3c55.html
If nothing works, maybe your sensor is faulty and needs a replacement.
userHeadPic ahsrab.rifat
2025-04-18 19:03:16
Do you have an Arduino Board? If yes, you can connect the sensor to that Arduino and run the I2C scanner code.
