SEN0158 IR light source questions (must modulate?)
I have bought these cameras to make a mouse-pointer style controller behavior for my project. I have finally figured out a sketch that at least is ready to find blobs. But I read somewhere that these cameras need modulated light sources, and that it cannot easily detect direct light sources, but actually needs reflected IR light?
These are some difficult restrictions, I believe people use these to track robots and stuff? I bet i can make this work with 850nm lights without reflecting them off a surface. Can someone let me know what light source methods have worked for you? Did you need to modulate the lights? what frequency?
I'm enclosing my sketch incase that helps.
THX!
Try one bright 850nm LED modulated at 38kHz as a test blob.
Verify with a smartphone camera (which can sometimes "see" IR light) to debug if your LED is on/modulated.
