Forum >SEN0170 - wind speed sensor not outputting expected voltage
Troubleshooting
userHead Eric.Muehleisen 2025-04-26 00:38:44 1236 Views3 Replies
First time using SEN0170 and not getting the expected output voltage. I get same results using 12v or 24v input power source.
12V DC power input:
RED = 12v positive
BLACK = 12v negative
YELLOW = Multimeter positive
BLACK = Multimeter negative
BLUE = NOT USED
Output is a constant ~9 mV. Doesn't change if wind increases/decreases. According to the connection diagram, the wiring is correct. Do I have a bad unit perhaps?
2025-05-01 19:31:19
The SEN0170 wind speed sensor may not output expected voltage due to wiring issues, insufficient power supply, or sensor damage. Verify connections, supply voltage, and test with known wind source. https://appsgb.pk/
userHeadPic GeorgeEvelyn
2025-04-26 21:08:19
The Arduino and the anemometer's power supply should share common grounds. Check if you are doing that.
userHeadPic ahsrab.rifat
Eric.Muehleisen wrote:
Not using an Arduino. Only using a power supply and a multimeter to measure output voltage.
2025-05-01 04:09:15
