Forum >Code using turbidity sensor?
I can not use the turbidity sensor to print 16x2 lcd screen. Please give me a standard code to upload for arduino uno r3 circuit output turbidity with corresponding voltage. Thank you!
2018-02-06 00:19:24 We don't provide code for showing turbidity on LCD, but you can first check if the turbidity sensor work well, and then according to the LCD screen wiki, you can display the data.
robert.chen
