Forum >Need to modify the code for Analog Dissolved Oxygen Sensor making it to work with Particle Photon
Hii,
i purchased the sensor from Dfrobot i.e Gravity: Analog Dissolved Oxygen Sensor _SKU:SEN0327-A.I could see the code given on the wiki details helped a lot and worked fine with arduino. But i need to use it for Particle Photon Board and i am unable to modify it as Photon is an ARM controller and they done have split memory space which arduino has being used by PROGMEM. So can someone help me to modify the code or suggest what can be done.
