Forum >UHF RFID MODULE-USB QUERIES
Easy IoT General
userHead Account cancelled 2018-02-10 03:31:55 3264 Views2 Replies
Good Day!
To whom it may concern,
I am currently doing a school project with your product, UHF RFID MODULE-USB. My problem is I can't find any code related to how it will be able to read tag data. I am using only Raspberry Pi. Do I need an arduino to make it read tag data? Pls answer ASAP. Thanks~
2018-03-03 06:12:47 The code we have is only an arduino code in user manual, if you want to use Rpi, you can try to read the command by serial. userHeadPic robert.chen
