Forum >sensor MQ-3
sensor MQ-3
How to use an MQ3 sensor with arduino to light LEDs.
please, I need your help.
2018-03-22 01:21:26 You can refer to the wiki of MQ3 https://www.dfrobot.com/wiki/index.php/ ... KU:SEN0128, and edit the code that when the analog signal is higher than a threshold value then the LED light up.
robert.chen
