Forum >DFRduino Ethernet Shield (Support Mega and SD) - On Mega
userHead kadu 2011-07-08 03:12:49 13717 Views19 Replies
Hello
I have a arduino mega and I try to use SD on this shield.
I made changes on SD exemple - pinMode(53, OUTPUT); to work on mega
When the card is not inserted, its oK, arduino show me a message.
When i insert a card (I try 2 sd cards), arduino give me a message of no card inserted.
My card is a 1gb card
I'm doing anyting wrong ?
2011-07-29 00:15:59 Hi Kadu,
I know I asked before, but are your uSD cards FAT format? Have you verified that they work on PC?
What brand microSD cards are you using?
userHeadPic Hector
userHeadPic Hector
2011-07-28 15:47:50 Hello Hector
I try your sketch, but still return "initialization failed".
I try CS in 4, 8 and 10,
I`m using a arduino mega 1280
The "ethernet" part of shield is OK, but SD isn`t :|
Tks for helping
userHeadPic kadu
Tks for helping
userHeadPic kadu
2011-07-27 19:12:00 Hi Kadu,
Which Arduino Mega are you using? (2560 or 1280?)
Try this code:
  SD card read/write
This example shows how to read and write data to and from an SD card file
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created  Nov 2010
by David A. Mellis
updated 2 Dec 2010
by Tom Igoe
This example code is in the public domain.
#include <SD.h>
File myFile;
  Serial.begin(9600);
  Serial.print("Initializing SD card...");
  // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
  // Note that even if it's not used as the CS pin, the hardware SS pin
  // (10 on most Arduino boards, 53 on the Mega) must be left as an output
  // or the SD library functions will not work.
  pinMode(53, OUTPUT); //for arduino Mega
  if (!SD.begin(8 )) {  //for Arduino Mega
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
// close the file:
    myFile.close();
    Serial.println("done.");
  } else {
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
  // re-open the file for reading:
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
    Serial.write(myFile.read());
    // close the file:
    myFile.close();
  } else {
// nothing happens after setup
userHeadPic Hector
Try this code:
  SD card read/write
The circuit:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created  Nov 2010
by David A. Mellis
updated 2 Dec 2010
by Tom Igoe
#include <SD.h>
File myFile;
  Serial.begin(9600);
    return;
  if (myFile) {
// close the file:
    myFile.close();
  } else {
  if (myFile) {
    // close the file:
    myFile.close();
  } else {
userHeadPic Hector
2011-07-27 07:43:00 Not Work :/
How alternatives I have to do this work?
sketch and output result
  SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether its working or not.
The circuit:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - depends on your SD card shield or module.
Pin 4 used here for consistency with other Arduino examples
created  28 Mar 2011
by Limor Fried
modified 16 Mar 2011
by Tom Igoe
// include the SD library:
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
const int chipSelect = 8;
  Serial.begin(9600);
  Serial.print("\nInitializing SD card...");
  pinMode(53, OUTPUT);    // change this to 53 on a mega
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card is inserted?");
    Serial.println("* Is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    return;
  } else {
  Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.print("\nCard type: ");
  switch(card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
      break;
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
      break;
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
      break;
    default:
      Serial.println("Unknown");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    return;
  // print the type and size of the first FAT-type volume
  long volumesize;
  Serial.print("\nVolume type is FAT");
  Serial.println(volume.fatType(), DEC);
  Serial.println();
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();      // we'll have a lot of clusters
  volumesize *= 512;                            // SD card blocks are always 512 bytes
  Serial.print("Volume size (bytes): ");
  Serial.println(volumesize);
  Serial.print("Volume size (Kbytes): ");
  volumesize /= 1024;
  Serial.print("Volume size (Mbytes): ");
  volumesize /= 1024;
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
The Output:
Initializing SD card...initialization failed. Things to check:
userHeadPic kadu
  SD card test
The circuit:
created  28 Mar 2011
by Limor Fried
by Tom Igoe
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
  Serial.begin(9600);
    return;
  } else {
      break;
      break;
      break;
    default:
    return;
  long volumesize;
  Serial.println();
  volumesize /= 1024;
  volumesize /= 1024;
void loop(void) {
The Output:
userHeadPic kadu
2011-07-25 20:26:07 Hi Kadu,
Sorry for the late reply.
Please try changing your code to the following:
!SD.begin(8)
OR
For the Arduino mega you should also change the pin 4 selection to pin 8.
Pinmode 53 is correct.
userHeadPic Hector
!SD.begin(8)
OR
userHeadPic Hector
2011-07-21 11:48:55 /***** CardInfo ******/
  SD card test
The circuit:
created  28 Mar 2011
by Limor Fried
by Tom Igoe
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
const int chipSelect = 4;
  Serial.begin(9600);
    return;
  } else {
      break;
      break;
      break;
    default:
    return;
  long volumesize;
  Serial.println();
  volumesize /= 1024;
  volumesize /= 1024;
void loop(void) {
/*****  Files  ******/
  SD card basic file example
This example shows how to create and destroy an SD card file
The circuit:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created  Nov 2010
by David A. Mellis
updated 2 Dec 2010
by Tom Igoe
#include <SD.h>
File myFile;
  Serial.begin(9600);
  if (!SD.begin(4)) {
    return;
  if (SD.exists("example.txt")) {
    Serial.println("example.txt exists.");
  else {
    Serial.println("example.txt doesn't exist.");
  // open a new file and immediately close it:
  Serial.println("Creating example.txt...");
  myFile = SD.open("example.txt", FILE_WRITE);
  myFile.close();
  // Check to see if the file exists:
  else {
  // delete the file:
  Serial.println("Removing example.txt...");
  SD.remove("example.txt");
  if (SD.exists("example.txt")){
  else {
  // nothing happens after setup finishes.
userHeadPic kadu
  SD card test
The circuit:
created  28 Mar 2011
by Limor Fried
by Tom Igoe
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
  Serial.begin(9600);
    return;
  } else {
      break;
      break;
      break;
    default:
    return;
  long volumesize;
  Serial.println();
  volumesize /= 1024;
  volumesize /= 1024;
void loop(void) {
The circuit:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created  Nov 2010
by David A. Mellis
updated 2 Dec 2010
by Tom Igoe
#include <SD.h>
File myFile;
  Serial.begin(9600);
  if (!SD.begin(4)) {
    return;
  else {
  myFile.close();
  else {
  // delete the file:
  else {
userHeadPic kadu
2011-07-20 18:44:47 Hi Kadu,
Could you please post the sketch code you are using?
Thanks,
Hector
userHeadPic Hector
Thanks,
Hector
userHeadPic Hector
2011-07-20 03:30:07 Hello
I try FAT and FAT32.
I try on ARduino 0.22 and ARduino 1.0 Beta
I try 2 diferrent micro sd card (1gb)
still show error message :/
userHeadPic kadu
userHeadPic kadu
2011-07-12 00:09:27 Hi Kadu,
Are your SD cards formatted to FAT type partitions?
Please make sure they are FAT, otherwise the ethernet shield will not recognize them.
userHeadPic Hector
userHeadPic Hector
2011-07-08 03:12:49 Hello
userHeadPic kadu
