Forum >dfrobot rover v2
dfrobot rover v2
userHead jdelcamp0 2018-03-06 18:12:41 2701 Views5 Replies
I have a rover v2 that is malfunctioning.
It appears to be a power regulator issue.
When powered by battery nothing plugged into the xbee slot works properly. Nor does a wifi breakout on the 5 v line.
But when powered by just the usb port everything works. If I then turn on the battery everything stops again.
I have measured the voltage at the 3.3, 5.0, outputs from both the ams1117 2.2 and 5.0. I don't have an oscilliscope so I can't see if there is noise.
Any thoughts on which chip is causing this behavior? How to diagnose further?
A rover plugged into the usb isn't going to rove.
2018-04-16 10:11:20 https://www.robotshop.com/en/dfrobotsho ... c-kit.html
I have a copy of the schematic which I downloaded from DFRobots wiki a long time ago. But They appear to be removed now.
I purchased this from DFRobot, but the only link I can find now is on Robotshop's site.
userHeadPic jdelcamp0
2018-04-11 21:29:50 I can't find anything about DFR0086, could you give me the link address of the product? There is a possibility that the battery may have interference with the board. userHeadPic robert.chen
2018-04-11 18:00:32 I am still looking for suggestions on how to diagnose the defective power circuit on my rover 2.
Any help would be appreciated.
2018-03-10 05:37:27 I have tried with a 7.4 lipo and the 8.1 wall wort, both from DFrobot.
Rover basic version 2.0 I think the part number is DFRobot(DFR0086)
2018-03-09 02:36:53 What's the battery you using? And could you specify the product name? userHeadPic robert.chen
