Forum >64 x 64 RGB LED Matrix Panel
Hi, I wonder if it works to connect 96 64x64 led panels and if so, is it enough with a rasberry pi?
2018-04-10 23:38:31 OK thanks! The complete panel will be built in three stages over 3 years. How about cooling, some ideas?
morten.meek
2018-03-14 23:43:13 It is possible, but it would consume more power, and you need to define the right array in the code.
robert.chen
