Forum >[Analog pH Sensor][SKU:SEN0169] Usage environment inquiry
I have used [PH meter (SKU: SEN0161)]. The test went well.
But I would like to receive the results continuously at 3-minute intervals.
I need to install it in the tank and operate it for a long time (even if I am not at home, I want to receive data every 3 minutes).
So I bought [Gravity: Analog pH Sensor / Meter Pro Kit for Arduino].
I put it in water for a month (continuously, continuously) and try to get data every 3 minutes.
Here's what I want to know:
- Does it get accurate results when installed in water?
- How long is the replacement cycle for supplies?
What I fear is one.
If [Gravity: Analog pH Sensor / Meter Pro Kit for Arduino] is not a product made for installation, I would have failed completely.
What I fear is one.
2018-03-16 23:51:14
I have a question.
Have you actually run it?
and I want to know the country of manufacture of chips.
yongun
I saw the text. thank you.robert.chen wrote: ↑Wed Mar 14, 2018 6:46 amSEN0169 is the industrial one for long time using, you can put it under water for a long time, and you just need to calibrate like every 3 months.
I have a question.
2018-03-16 23:50:43 I saw the text. thank you.
I have a question.
yongun
I have a question.
2018-03-14 22:46:50 SEN0169 is the industrial one for long time using, you can put it under water for a long time, and you just need to calibrate like every 3 months.
robert.chen
