Forum >[Bluetooth bee] change pairing code
I'm wondering if it's possible to change the pairing code of the Bluetooth bee ?
http://www.dfrobot.com/index.php?route=product/product&filter_name=bluetooth&product_id=193
And in the best case to set it in an "auto-pairing" mode - like no code... ?
I've found nothing about this on this forum nor on the internet...
Someone already tried this ?
sincerly,
K.
sincerly,
K.
2011-11-03 21:41:23 I'm not sure why your other idevices are not seeing the btbee...If your macbook sees the bee, then I would imagine the problem is an incompatibility with the ipad and iphone. But I can't be certain, since I don't have an iphone or ipad here to test with.
Hector
2011-11-03 04:52:53 Thanks ! I'll give a try to theses ATs... :)
Do you know why this BTBee is seen by my laptop (apple mac book pro 13") and not by an iphone nor an ipad ? I've read that the apple BT is limited... Is this pb come from Apple or my device config ?
Thanks for your time !
K.
kloom
K.
2011-10-31 22:53:12 Hi Koom,
Here is the data sheet for the Bluetooth chip. In the data sheet there are some "AT" commands you can use to change the pairing pin.
[url=https://www.dfrobot.com/image/data/TEL0026/TEL0026_Datasheet.pdf]https://www.dfrobot.com/image/data/TEL0026/TEL0026_Datasheet.pdf[/url]
Hector
