Forum >DFRduino Sound Player
userHead any 2011-09-07 18:26:06 13820 Views29 Replies
I just brought that shield and waiting to get it... in the meantime I wrote a test programm, but some things are not clear enought for me.
Why in the example after the volume set you also send this string "\\yes\r\n"?
If I send "\\somg.mp3\r\n" will the shield start plaing?
If I send "\\somg.mp3\r\n" while the shield is playng that song already I will get "Play ok" or "Over" if the song ended, how to play 2 times the same song?
Can I have a full command set list? Thanks
2011-10-24 23:50:52 Hi Paliee,
I have updated the wiki with a connection diagram at the bottom of the wiki.
[URL=https://www.dfrobot.com/wiki/index.php?title=DFRduino_Player_(SKU:DFR0112)] DFR0112 Wiki [/URL]
userHeadPic Hector
userHeadPic Hector
userHeadPic Hector
2011-10-24 21:49:22 [quote="Hector"]
Hi Paliee,
Yes, you need to place the 'track1' name into the command. Give it a try. If it doesn't work for some reason let me know.
[/quote]
hye hector...i'm looking for the connection between my player with my arduino...do you know how to connect D0 and D1 at my player to my arduino???i'm using duemilanove arduino~~
userHeadPic paliee
Hi Paliee,
[/quote]
userHeadPic paliee
Hi Paliee,
[/quote]
userHeadPic paliee
2011-10-13 19:41:38 Hi Paliee,
userHeadPic Hector
userHeadPic Hector
userHeadPic Hector
2011-10-13 03:12:45 hye...just want to ask...if my sound file 'track1'...so i need to write that name in my command???i mean by replacing it with the 'yes' in your wiki~~ userHeadPic paliee
2011-09-19 19:05:20 Hardmouse,
Sorry the player can only read 1Gb cards at the moment. We are working on an updated opensource version at the moment. The new version will be able to read larger memories.
Hector
userHeadPic Hector
Hector
userHeadPic Hector
Hector
userHeadPic Hector
2011-09-19 18:51:47 Does it read 2G SD card? and I format it in FAT format. userHeadPic hardmouse
2011-09-17 00:23:09 Hi Hardmouse,
Does the player recognize your SD Card? The LED should blink green once when you power it. After that it should turn off. If the LED is still blinking that means there is some kind of problem.
userHeadPic Hector
userHeadPic Hector
