Forum >HMC5883 or HMC5843
HMC5883 or HMC5843
userHead baxter 2011-12-29 09:06:27 5184 Views3 Replies
i need to know that what is the correct model of magnetometer on "9 Degrees of Freedom - Razor IMU" and 9 Degrees of Freedom - Sensor Stick ?
HMC5883 or HMC5843? because on sparkfun site they have HMC5883 !
please check this out
[url=http://www.dfrobot.com/index.php?route=product/product&filter_name=9%20dof&product_id=476] 9 Degrees of Freedom - Sensor Stick[/url]
[url=http://www.dfrobot.com/index.php?route=product/product&filter_name=9%20dof&product_id=187]9 Degrees of Freedom - Razor IMU[/url]
2011-12-30 18:23:36 Yes,
Its the label on the chip. Its the new version with the HMC5883. We will also update the picture.
userHeadPic Hector
2011-12-30 11:27:02 tanks for updates.
"L8832105" is label of HMC5883L?
please update both pictures also because old sensor is in pictures.
userHeadPic baxter
2011-12-29 18:55:38 Hi they are both using the L8832105.
Good catch. I'll update the site description shortly.
userHeadPic Hector
