Forum >128x64 lcd code generation
userHead dev5994 2011-12-31 00:00:02 5338 Views9 Replies
I was wondering how you guys created the dfrobot logo in the picture example found on this page:
http://www.dfrobot.com/index.php?route=product/product&path=53&product_id=240
I can't find a program to generate the hex array and really would like to know how you did it!
2018-03-14 22:57:13 How about light the pixel by using the Sin function. Hope this blog's code can give you some idea http://www.instructables.com/id/Display ... kia-LCD-5/ userHeadPic robert.chen
2018-03-12 09:11:07 Hi all im new to using the 12864 display, from the code i have worked out how to display stored numbers, but im trying to display a sine wave and there is no example of how to draw anything, can anyone help? userHeadPic ammcinnes101
2012-01-04 18:29:50 Hi Dev5994,
Would you mind sharing the process so that others might be able to use it?
userHeadPic Hector
2011-12-31 04:26:24 This program only outputs BASIC however a quick writeup and now i have a program that converts it to C. Thank you for the help! userHeadPic dev5994
2011-12-31 02:13:54 We found an alternative!
8)
userHeadPic Hector
2011-12-31 01:45:37 Dev,
I asked, and they used a Chinese software called CharacterMatrix. Unfortunately its all in Chinese...We are looking for an alternative in English, but aren't having much luck.
userHeadPic Hector
2011-12-31 00:00:02 Hi,
I'm not sure how they made the graphic.
Have you seen this page:
http://mikenz.geek.nz/blog/1006/mindkits-128x64-graphic-lcd-and-arduino/
userHeadPic Hector
2011-12-31 00:00:02 Yes I have. I've done a lot of research on the topic and i can't find a program that does it quite right. Is it possible for you to find out how they did it? userHeadPic dev5994
