Forum >DFRduino fonction
DFRduino fonction
userHead ro2 2012-01-05 11:37:13 4848 Views5 Replies
Hello every body
I want make a project with a arduino and a DFRduino in I2C.
I want play a specific file into the sd card
the files are named 001.mp3; 002.mp3
can you tell me if is a "play 002.mp3 " exist?
thank you
2012-01-16 19:21:30 Hi,
I think you might be looking for this command: [font=arial, helvetica, sans-serif][size=2]Continue Play "\:s\r\n" Return "start\r\n"[/size][/font]
[font=arial, helvetica, sans-serif][size=2]Give it a try, otherwise you might need to program the arduino to send a "play" command every few minutes or time it to send the command at the end of the track.[/size][/font]
userHeadPic Hector
2012-01-15 05:48:44 all is right the sound work fine.
Now I want to play the song in Loop (when the song is end, it start a other time without end)
can you tell me if is possible?
userHeadPic ro2
2012-01-06 18:17:48 Try this:
TwiSend("\\002\r\n");
or replace "002" with the name of the file, just don't add ".mp3"
userHeadPic Hector
2012-01-06 11:55:27 thank you for the answel
yes is for a dfrduino player
in the wiki I found:
    Pause Play "\:p\r\n" Return "pause\r\n" if success
    Continoue Play "\:s\r\n" Return "start\r\n" if success
    Play next "\:n\r\n" Return "next\r\n" if success?Return "false\r\n" if failed
    Play previous "\:u\r\n" Return "key up\r\n"
    Set the volume "\:v 255\r\n"?set the volume, from 0 (minimum)-255 (maximum), Return "vol set ok" if success
but nothing in play a specific file?
userHeadPic ro2
2012-01-05 18:12:51 Hi Ro2,
Are you talking about the DFRduino player??? If so, please look at the wiki, you don't need to include the ".mp3" in the command. Just the name of the track.
[url=https://www.dfrobot.com/wiki/index.php?title=DFRduino_Player_(SKU:DFR0112)] DFRduino player wiki[/url]
If you still have some questions please let me know. Make sure to check the green status LED.
userHeadPic Hector
