Forum >Romeo V1.0 Wireless Jumper Missing
Hi!
I just got my new Romeo V1.0 Board and the Bluetooth V3 Module, placed . As I understand, I can load sketches to the board, if the BT-Module is not present.
In the manual, I saw the Wireless Jumper (right next to the RST Button), which I could open and close, if I want to disable the BT-Module.
Here is my problem: The jumper does not exist!
Do I need to remove the BT-Module every time, I want to upload a new sketch, or is there a workaround?
best regards,
sumpfgottheit
best regards,
sumpfgottheit
2012-03-01 23:47:48 Hi,
The new version of the Romeo does not have the wireless jumper select. you need to remove the bluetooth module in order to program the Romeo. With the jumper it was the same case, you needed to remove the jumper which is more difficult...
Hector
