Forum >DFrobot motorshield 2A max 3.3v ouput
userHead T!mmy 2012-03-01 00:56:47 3102 Views2 Replies
Hi all,
If I measure the motor output without a motor I only get 3.3v output. Both PWM and PLL. I use power from the Arduino. I use the example sketch with "value" set to static "255".
What am I doing wrong?
2012-03-02 05:47:25 Hi, Will do that this evening ^^ userHeadPic T!mmy
2012-03-01 03:52:03 Hello,
Could you please post a picture about your hardware connection and the sketch?  ???
userHeadPic Lauren
