Can Gravity: Digital Microwave Sensor (Motion Detection) be place next to a TFT display?
![userHead](https://dfimg.dfrobot.com/dfPortrait2.png)
Can Gravity: Digital Microwave Sensor (Motion Detection) be use next to a TFT display? Since the sensor use microwave, would it cause problem to the longevity of the TFT display?
Thank You
Thank You
2018-04-04 22:12:20 The display will be on the left side and the microwave sensor is on the right side, next to the display, both facing up. What I worry about is when you place a conventional microwave next to a TV you will see interference, will this sensor have or can create the same interference with a tft display?
sdeng
![userHeadPic](https://dfimg.dfrobot.com/dfPortrait2.png)
2018-04-04 16:04:14 Where will you place the sensor and the display, because the microwave sensor has a detecting face where you can avoid the detection angle to place the display.
robert.chen
