Forum >using Light Disc with 7 SMD RGB LED with Netduino
userHead Account cancelled 2011-11-26 09:26:45 4656 Views5 Replies
Can i plug the Light Disc with 7 SMD RGB LED directly with a Netduino ([url=http://www.dfrobot.com/index.php?route=product/product&path=53&product_id=350]http://www.dfrobot.com/index.php?route=product/product&path=53&product_id=350[/url])?
If not, then what do i need to do so ?
2012-03-08 23:21:38 Hi Maxie,
I'm not sure why you included links in your post, but its not appreciated. This post is for the 7 LED disk. From what you are describing it seems you have a 12LED disk. Do you know which version of the disk you have?
userHeadPic Hector
2012-03-06 21:23:10 I have loaded the code but I suspect there is an error in the RGB_receive1.pde. When I send the sample script "co029901s" all of the LEDs light up blue as they should except D10 lights up red and green all of the time. userHeadPic MaxieGodde
2011-12-12 18:24:31 Hi nfx,
This LED disk's voltage is provided by the PWM pins. The GND pin is needed to complete the circuit. You could just provide 5V power to a certain pin to have it turn on continuously.
userHeadPic Hector
2011-12-12 09:56:36 I see that the DFR0106 unit is common ground.
Do you have a common +5  or +voltage version? did see s picture showing one.
userHeadPic wolfstar
2011-11-26 18:26:15 Yes. You can. simply connect the disc pin to netduino digital pin will work. userHeadPic R2D2C3PO
