Forum >SKU:TEL0019 doesn't send the data
userHead qeos 2012-03-11 08:29:34 2833 Views2 Replies
WiFi shield accepts data and works normally. But it doesn't send the data.
When I use Serial Monitor from Arduino tools, all works fine. Arduino do receive all data.
I am afraid something with wifi shield.. Because, connecting with Putty in Raw mode I get nothing from shield.
Has any ideas about this trouble?
2012-03-12 19:39:42 qeos,
I'm glad you got it working. Let us know if you need anything else.
userHeadPic Hector
2012-03-12 17:57:00 I think I could force to work it. Somewhere I read that it is necessary to press 10 seconds reset, that flash the module. At me after that, settings remained, but Putty began to show the answer.
As I understood that jumper "Serial mode" switches a mode of an exchange of Arduino with shield. Respectively it should be off.
userHeadPic qeos
