Forum >X-Board v1.1
X-Board v1.1
userHead synekvl 2012-03-23 07:26:35 4177 Views5 Replies
Hi to all,
I have the older version v1.1 and I would like to know what maximum supply voltage should be on the white JST connector - 5V as on USB or lower ?? Unfortunately the schematic on wiki is for the latest X-Board version only ... :-[
Thanks for your suggestions
Vladimir
2012-03-26 23:18:08 HI: forget to post the link.
Here it is: [url=https://www.dfrobot.com/image/data/DFR0133/X-Board%20V1.1%20Sch.pdf]https://www.dfrobot.com/image/data/DFR0133/X-Board%20V1.1%20Sch.pdf[/url]
userHeadPic R2D2C3PO
2012-03-26 22:43:00 Hi Ricky,
may I place a small reminder on old v1.1 schematic (if available, of course)..... ??
userHeadPic synekvl
2012-03-23 08:48:52 Power xboard with only 1 lipo won't harm it. We use fully charged 1 unit lipo battery to play the board without any problem.
I will try to find the old schematic for you. But have to do it 8 hours later. It is 0:30 am .....
2012-03-23 08:45:17 Thanks Ricky, you are faster than the light :-)
Even I can't find clear information on JST I take the connector is foreseen for 1 Li-pol = up to max. 4,2V when fully charged. BTW is still available the link to schematic for the older X-Board ??
Have a nice evening
Vladimir
userHeadPic synekvl
2012-03-23 08:05:32 The white JST is 3.7V. check the wiki for old  version
[url=https://www.dfrobot.com/wiki/index.php?title=X-Board_(SKU:DFR0133)]https://www.dfrobot.com/wiki/index.php?title=X-Board_(SKU:DFR0133)[/url]
