Forum >Waterproof Ultrasonic Sensor with Separate Probe
userHead Account cancelled 2018-04-05 07:31:54 2022 Views1 Replies
Good afternoon, would it be possible to reduce the detection distance using two sensors at the same time? one sending ping and another listening? If possible, what would be the minimum distance that could be reached?
Thank you very much
2018-04-09 23:41:14 The minimum distance it can detect is 25cm, if you want to measure less distance, we recommend to use Lidar instead of ultrasonic sensor. userHeadPic robert.chen
