Forum >IR transmitter module (dfr0095)
userHead LeSanglier 2012-03-27 08:46:29 4459 Views5 Replies
I bought 4wd MiniQ (ROB0050) and the digital IR Transmitter Module (DFR0095).
For controlling the mini car, I use the new irmote library ([url=http://www.arcfn.com/2009/08/multi-protocol-infrared-remote-library.html]http://www.arcfn.com/2009/08/multi-protocol-infrared-remote-library.html[/url]), that run perfectly with a normal remote controller (Sony Model).
With the Ir Module, I can control the mini car but I must place the module very near the car. I would to know how to increase the power of the ir module ?
You can find my sketchs here : [url=https://gitorious.org/voiture_4wd_arduino]https://gitorious.org/voiture_4wd_arduino[/url]
2012-04-05 19:02:02 Awsome!
Glad you got it working!
Thanks for sharing the video!
userHeadPic Hector
2012-04-03 02:52:48 Hello,
It's run !!
You can see my test here : [url=http://www.youtube.com/watch?v=aSei7TQPt20]http://www.youtube.com/watch?v=aSei7TQPt20[/url]
userHeadPic LeSanglier
2012-03-28 18:24:25 The IR transmitter (The Remote) is using the NEC standard. userHeadPic Hector
2012-03-28 03:00:44 Hi,
I tried with the included IR library and with another ir remote, that's run perflectly.
The ir transmitter has the specific NEC standard ?
2012-03-27 18:20:23 Hi Lesanglier,
Have you tried using our included IR library along with the NEC codes? Our IR remote uses the NEC standard. You should be getting a good distance with our setup.
userHeadPic Hector
