Forum >Question about the IO Expansion Shield For Arduino(V5)
userHead Piero78 2012-05-17 04:55:33 2731 Views1 Replies
Hi, I've a question about the IO Expansion Shield For Arduino(V5), how many servos I can connect to them? 14 or 20? Thanks!
2012-05-18 05:55:44 IO shield supports upto 13 servos. However, we recommended to use only 6 servos with hardware PWM control.
Arduino servo library is able to soft emulate PWM output on all digital pins.
userHeadPic R2D2C3PO
