Forum >DFRduino GPS Shield For Arduino > Active Antenna ?
userHead thierry 2012-05-10 10:56:47 4468 Views4 Replies
My question is: It's possible to connect a Active GPS Antenna ?
In the descriptif of card, it' annoted: "Antenna supervisor and supply"
For me, it must have two requirements for "Antenna supply”
[u]1er requirement: [/u]
this module series is LEA-5A, LEA-5, LEA-5T Or [b] LEA-5H[/b] ([url=http://www.u-blox.com/en/gps-modules/pvt-modules/previous-generations.html]http://www.u-blox.com/en/gps-modules/pvt-modules/previous-generations.html[/url])
It’s ok
[u]2nd requirement: [/u]
it takes a VCC (3.3V) in the pin 18 “VCC_REF” ? but in your schema “VCC-REF” is not connected.
this is correct? Or this is possible by software command ?
Regard
Thierry
2012-05-28 21:47:06 Hi Thierry,
I am Mexican, I thought because of the way you worded some part of your post you might speak Spanish, but French also makes sense :D
I'm glad you have the shield working for you.
Many places are starting to have their own Maker Faire. I hope France will have one soon. I think French people are very creative and a Maker Faire in France would be very interesting :)
userHeadPic Hector
2012-05-26 15:07:20 Thank Hector for the response . No Speak Espagnola (I am French). My friend speaks Spanish very well. why?
I bought the card. It works very well. I'm on NetDuino (3.3V) . Tested so far with uart.
this is a very good card (good choice of GPS)
"Maker Faire in San Francisco, California"  that's good. I do not pensse we have this kind of event in France.
Regards
Thierry
userHeadPic thierry
2012-05-15 00:18:10 Hi Thierry,
Do you speak spanish?
Sorry for the late reply. We are very busy getting ready for Maker Faire in San Francisco, California.
To answer your question:
Pin 18 is disconnected. From looking at the schem for the GPS chip you could solder a resistor between Vcc_RF and V_ANT, but this would be under your own risk, and it is dangerous. You could permanently damage your GPS.
We will put in a small jumper to enable users to use an active antenna in the next revision of this shield
userHeadPic Hector
2012-05-12 11:53:01 up userHeadPic thierry
