Forum >DFRduino mega2560 V2.0 Reseting while running.
userHead Account cancelled 2012-05-27 10:02:44 2705 Views2 Replies
Hope somebody here can help
I'm using a DFRduino mega2560 V2.0 with a Mega IO Expansion Shield V2.1 powered via a 9V tranformer. I have 6 servos connected to the Shield.
The sketches loads Ok, but when running the complete sketch (part in loop) only runs once, then resets about half way through the loop the second time, then runs about half, again resets, and carries on resetting about half way through the programme.
Any idea what might be causing this?
2012-05-28 21:54:32 How much current can the 9V transformer supply?
Try testing with only 1 servo, as Ricky suggested, if it works try adding more servos 1 at a time.
userHeadPic Hector
2012-05-27 17:07:58 Try to work with only one servo. It may be caused by insufficient current. userHeadPic R2D2C3PO
