CAN BUS Shield PROBLEM
I bought recently the DFrobot CAN BUS Shield V2.0
I attached it to my arduino uno and loaded up the send data demo program.
The port monitor shows only "DFROBOT's CAN BUS Shield init ok!" and no CAN message afterwards just blank. What could be the problem? Broken shield ?
my setup is simple arduino uno, can bus shield, arduino connected via usb cable. Tried connecting it via the dc connector, nothing worked.
Please Help.
The code that i used \/
// demo: CAN-BUS Shield, send data
#include <df_can.h>
#include <SPI.h>
const int SPI_CS_PIN = 10;
MCPCAN CAN(SPI_CS_PIN); // Set CS pin
Serial.begin(115200);
int count = 50; // the max numbers of initializint the CAN-BUS, if initialize failed first!.
do {
CAN.init(); //must initialize the Can interface here!
if(CAN_OK == CAN.begin(CAN_500KBPS)) // init can bus : baudrate = 500k
Serial.println("DFROBOT's CAN BUS Shield init ok!");
break;
else
Serial.println("DFROBOT's CAN BUS Shield init fail");
Serial.println("Please Init CAN BUS Shield again");
delay(100);
if (count <= 1)
Serial.println("Please give up trying!, trying is useless!");
}while(count--);
unsigned char data[8] = {'D', 'F', 'R', 'O', 'B', 'O', 'T', '!'};
// send data: id = 0x06, standrad flame, data len = 8, data: data buf
CAN.sendMsgBuf(0x06, 0, 8, data);
delay(100); // send data per 100ms
Please Help.
#include <df_can.h>
#include <SPI.h>
do {
break;
else
delay(100);
if (count <= 1)
}while(count--);
2018-04-20 21:18:45 Your monitor is connected to your serial port I assume... since "Serial.println("DFROBOT's CAN BUS Shield init ok!")" is printed on the screen. However, CAN.sendMsgBuf(0x06, 0, 8, data); is not a serial port command, so I'm not sure you should be expecting to see anything on your terminal window. BMagnan
