Forum >Arduino Mega + DfRobot USB SHield + Android 2.2
userHead robb83 2012-07-02 07:43:57 4280 Views2 Replies
Hi!
I would like a bit of help, please.
I'd like to connect my android 2.2 phone with arduino, via ADB.
The items:
- arduino mega 2560R3( not ADK)
- DFRobot usb shield
- android 2.2
- MicroBridge library http://labs.arduino.cc/uploads/ADK/GettingStarted/arduino_bundle_ADB.zip]http://labs.arduino.cc/uploads/ADK/GettingStarted/arduino_bundle_ADB.zip
I tried SS = 10 and SS = 53, but neither worked, i also tried switching the jumpers and also tried the commented out part of the source code.
I could use my telephone program on pc with ADB.
The serial monitor writes this: "Error: OSCOKIRQ failed to assert".
And i think it stops at this line (waiting forever):
 while (!(max3421e_read(MAX_REG_HCTL) & bmSAMPLEBUS));
And finally i connected keyboard to arduino, with USB Library 2.0, by leaving all on default (ss jumper = 10, int = 9) and work.
What else could i try, what are the good settings?
Thanks!
2012-07-02 20:27:25 glad to see you figured it out and share the result with us. Really appreciate. Every little help will make the community better.
Cheers Robb83
userHeadPic R2D2C3PO
2012-07-02 10:16:11 I looked over the code of USB Host Library 2.0 and MicroBridge, and when i saw that MicroBridge uses GPX, i took it out, and now it works. Now i'd just have to know what GPX does...
Attached diff files (based on [url=http://microbridge.googlecode.com/issues/attachment?aid=90004000&name=MicroBridge-Arduino-Patched-IDE-1.x.zip&token=2PqxZpvPsTd08KDntjCOXuWvuQg%3A1341091146361]http://microbridge.googlecode.com/issues/attachment?aid=90004000&name=MicroBridge-Arduino-Patched-IDE-1.x.zip&token=2PqxZpvPsTd08KDntjCOXuWvuQg%3A1341091146361[/url]).
userHeadPic robb83
