Forum >Driver for DFRobot XBee Usb V2 not starting
userHead Asterion 2012-07-14 19:24:20 2961 Views2 Replies
Two questions:
1) I am running Windows 7 Home Edition SP1 and I have a DFRobot XBee USB V2 but when I went to install the driver the driver installation claims an ERROR 10, driver did not start problem. Has anyone come across this and fixed the problem?
2) Additionally, has anyone else tried using the DFRobot XBee USB with Synapse SNAP instead of XBee? They're supposed to be form fit replacements so I am curious if people have found that to be true.
2012-07-20 01:05:59 1. I will try on another computer to see if the same problem happens.  That may not help as the actual driver called by the config file is sitting on the computer so unless there was something I was supposed to download onto the USB dongle then it might simply turn out to be a QC problem on the dongle.
2. Yes, that's the claim but the question was has anyone here tried.  No matter, I guess I will try.
userHeadPic Asterion
2012-07-19 21:58:12 Hi,
1. I have not encountered this problem before. You might want to try another PC if you have access to one.
2. If it is a form fit replacement, you should not have any trouble with it working.
userHeadPic Hector
