Forum >FireBeetle Board-328P with BLE4.1
Easy IoT General
userHead hellfire3456789 2018-04-22 18:34:54 4575 Views3 Replies
Hi, I want to do a project using the DA14681 processor and I'm wondering if the FireBeetle Board-328P with BLE4.1 lets me directly code the DA14681 or whether I can only program the ATMega328p?
If not, is there something else I can get to interact with the TEL0120 module directly?
2018-05-11 21:14:36 Since the bluetooth and 328P uses the same serial, when you uploading the firmware you can use the USB port of the board to upgrade the firmware. userHeadPic robert.chen
2018-04-30 01:39:15 Can I upload firmware directly to the DA14681 in the TEL0120 or is it stuck with what's shipped with it and I can just use it as a bluetooth bridge for the 328P? userHeadPic hellfire3456789
2018-04-29 00:56:30 Firebeetle 328P has combine TEL0120 and the 328P main chip. what do you mean code directly the DA14681? userHeadPic robert.chen
