Forum >wifi shield v2.2 Server (ADHOC connection)
userHead emerson_afs 2012-12-04 19:09:19 4958 Views0 Replies
Hello !!
I'm trying to set the connection between my arduino and Iphone.
As i read, I needed to set up a AD HOC connection so I could connect to the network and after that send some comands by browser.
When I started, I became to face some errors and for that i had to fix the library (WiShield)...
I`m a noob and don`t know what else I suposed to do.... by the way I`m not sure the right position of the jumpers after uploading the code...
The code I uploaded is above:
#include
#define WIRELESS_MODE_INFRA 1
#define WIRELESS_MODE_ADHOC 2
// Wireless configuration parameters ----------------------------------------
unsigned char local_ip[] = {192,168,1,125}; // IP address of WiShield
unsigned char gateway_ip[] = {192,168,1,1}; // router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0}; // subnet mask for the local network
const prog_char ssid[] PROGMEM = {"arduino"}; // max 32 bytes
unsigned char security_type = 0; // 0 - open; 1 - WEP; 2 - WPA; 3 - WPA2
// WPA/WPA2 passphrase
const prog_char security_passphrase[] PROGMEM = {"1234567"}; // max 64 characters
// WEP 128-bit keys
// sample HEX keys
prog_uchar wep_keys[] PROGMEM = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, // Key 0
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // Key 1
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // Key 2
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 // Key 3
// setup the wireless mode
// infrastructure - connect to AP
// adhoc - connect to another WiFi device
unsigned char wireless_mode = WIRELESS_MODE_ADHOC;
unsigned char ssid_len;
unsigned char security_passphrase_len;
// End of wireless configuration parameters ----------------------------------------
// This is our page serving function that generates web pages
boolean sendMyPage(char* URL) {
    // Check if the requested URL matches "/"
    if (strcmp(URL, "/") == 0) {
        // Use WiServer's print and println functions to write out the page content
        WiServer.print("");
        WiServer.print("Hello World!");
        WiServer.print("");
        // URL was recognized
        return true;
        if (strcmp(URL, "/switchOn") == 0) {
        WiServer.print("");
        WiServer.print("Switch Mode On");
        WiServer.print("");
        return true;
            if (strcmp(URL, "/switchOff") == 0) {
        WiServer.print("");
        WiServer.print("Switch Mode Off");
        WiServer.print("");
        return true;
    // URL not found
    return false;
  // Initialize WiServer and have it use the sendMyPage function to serve pages
  WiServer.init(sendMyPage);
  // Enable Serial output and ask WiServer to generate log messages (optional)
  Serial.begin(57600);
  WiServer.enableVerboseMode(true);
void loop(){
  // Run WiServer
  WiServer.server_task();
  delay(10);
