Forum >Dissolved Oxygen sku sen 0237 A and pH sku sen 0161
userHead satrio.nurcahyo 2018-04-30 18:55:41 1593 Views1 Replies
I use dissolved oxygen sensor and also pH sensor. After I combine the program and place the two sensors into the same water, the result of the measurement by the pH sensor becomes 0. What is the solution?
2018-05-05 01:35:44 You need to use a signal isolator to avoid the signal interference. userHeadPic robert.chen
