Forum >Change baud rate of Bluetooth V3 using Arduino board
userHead robvoi 2012-07-06 11:47:54 5027 Views4 Replies
is it possible to change the baud rate of the bluetooth V3 module using the serial interface of the arduino board?
Like cross connecting Rx/Tx of the board and the module and send the required bytes?
Robert
2012-09-28 20:06:34 If you have the arduino Uno Dip version. You could remove the atmega328 chip. Then connect the D1(TX) pin to the Bluetooth V3 TX pin, and connect the D0(RX) pin on the Arduino board to the Bluetooth V3 RX pin.
Because the atmega8u2 chip is working as a USB to TTL converter. And programming interface(TTL pins) is connected to the Arduino D0/D1(TX on atmega8u2 to RX on atmega328). So you could directly use it to work as a USB to TTL converter temporarily.
userHeadPic Lauren
2012-09-28 07:58:50 hi HACTOR
how to use an arduino board and program to change the baud rate because i have no of usb converter..
please explain in detail..thanks a lot
userHeadPic nazhirin
2012-07-06 23:02:55 Hi Hector,
I have a Romeo board. So option 2 doesn't work.
Do you think it works with soft serial? (is it normal serial communication at all?)
Do you have any chance to test it? I think a lot of Bluetooth Module V3 owners would be glad about it.
Robert
userHeadPic robvoi
2012-07-06 15:34:36 Hi Robert,
I suppose it's possible, but you would need to:
A. Write a sketch to do it for you
or
B. If you have a DIP package Arduino (the kind where you can remove the Arduino chip) and just talk to the bluetooth module directly through the USB port.
Here is a post that confirms this:
[url=http://arduino.cc/forum/index.php/topic,52574.msg375214.html#msg375214]http://arduino.cc/forum/index.php/topic,52574.msg375214.html#msg375214[/url]
userHeadPic Hector
