Forum >arduino soil moisture sensor to measure Electrical soil conductivity
userHead massimo.marcon 2012-10-04 00:34:01 5510 Views3 Replies
Hello, I'd like to have your feedback about the feasibility of the following idea:
could the DFR arduino soil moisture sensor USED to measure Electrical soil conductivity ALSO?
As matter of fact I read that its working principle is measuring the resistivity between its electrodes, so by finding the proper formula may be possible to measure the soil conductivity...
2012-11-14 17:04:19 Hi Massimo,
The schematics for all of our products are provided in the product page.
[url=https://www.dfrobot.com/index.php?route=product/product&filter_name=moisture&product_id=599#.UKLtz4d1-_4]https://www.dfrobot.com/index.php?route=product/product&filter_name=moisture&product_id=599#.UKLtz4d1-_4[/url]
userHeadPic Hector
2012-11-14 14:06:28 hello Hector,
thanks for reply
do you have available the sensor schematic?
I'd like to check it out to see if with some slight modification I can get this goal
userHeadPic massimo.marcon
2012-10-16 20:09:53 Hi massimo,
I'm not sure how to answer your question. But here is a link that might give you a better idea:
[url=http://www.ehow.com/how_5901417_measure-soil-conductivity.html]http://www.ehow.com/how_5901417_measure-soil-conductivity.html[/url]
It sounds like it might be possible, but the soil should be wet in order for it to work.
userHeadPic Hector
