Forum >SPI on Romeo all-in-one V1 vs. V1.1
userHead robvoi 2012-11-13 00:00:28 5305 Views8 Replies
I am trying to get a nrf24L01 network up and running.
The nrf24L01 works fine on the romeo all-in-one V1 but not on the V1.1.
Details you can find here:
[url=http://arduino.cc/forum/index.php/topic,131566.msg991595.html#msg991595]http://arduino.cc/forum/index.php/topic,131566.msg991595.html#msg991595[/url]
Is there any difference between the V1 and the V1.1 in respect to SPI?
Robert
2012-11-27 01:53:04 No. I only have the nrf24L01. And for my next two projects I don't need any other SPI device ;-)
userHeadPic robvoi
2012-11-27 01:44:56 [quote="robvoi"]
Hey Lauren,
thanks for testing. I don't think that the board works with one SPI device but not with the other.
I expect my board to be defect then.
Unfortunately the second one.
Robert
[/quote]
Do you have the other SPI devices in hand? Maybe a SPI IMU sensor or a SD card module(a cheap solution ;))? You could try it with your SPI devices.
userHeadPic Lauren
2012-11-26 23:19:04 Hey Lauren,
Robert
userHeadPic robvoi
2012-11-23 09:20:19 Hi Robert,
I just tested it on my Arduino Wifi shield, which use the SPI interfact. And it works fine. I can scan the network properly.....
So it's not compatible with different SPI devices? ???
Really strange....
userHeadPic Lauren
2012-11-23 04:44:17 Hi,
no, didn't find a reason. I bought a Arduino Nano - no problem.
On the Uno all pins work fine as in/out pins. Not sure how to further test the V1.1 version.
Can you test a V1.1 all-in-one with a SPI device? At least I don't have a second one to exclude a hardware failure. :-)
Robert
userHeadPic robvoi
2012-11-22 23:47:00 Hi robvoi,
What about your testing? Do you figure out the reason why the romeo v1.1 can't work with nrf24L01?
userHeadPic Lauren
2012-11-14 05:20:50 I don't have an UNO board to test it with. I'll receive a DF-Nano tomorrow and will test it with it.
Not that the results would explain something ...
Still it is strange. I have no other problems with the board. So I don't think it is defect.
userHeadPic robvoi
2012-11-14 04:47:35 Hi robvoi,
Considering that the main difference between Romeo 1.0 and 1.1 is the bootloader. Any other hardware modification won't cause a big difference. So... Could you try to test it on a standard Uno board to eliminate this possibility?
userHeadPic Lauren
