3-wire Serial LCD Module (SKU:DFR0091)
The Parallel code...
RS = 17; Analog Pin3
RW = 16; Analog Pin2
EN = 18; Analog Pin4
... does not compile, giving errors;
C:\Program Files (x86)\arduino-1.0.1\libraries\LCD12864R\LCD12864R.cpp: In member function 'void LCD12864R::setPins(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)':
C:\Program Files (x86)\arduino-1.0.1\libraries\LCD12864R\LCD12864R.cpp:29: error: 'digitalWrite' was not declared in this scope
C:\Program Files (x86)\arduino-1.0.1\libraries\LCD12864R\LCD12864R.cpp: In member function 'void LCD12864R::delayns()':
C:\Program Files (x86)\arduino-1.0.1\libraries\LCD12864R\LCD12864R.cpp:51: error: 'delayMicroseconds' was not declared in this scope
C:\Program Files (x86)\arduino-1.0.1\libraries\LCD12864R\LCD12864R.cpp: In member function 'void LCD12864R::Initialise()':
C:\Program Files (x86)\arduino-1.0.1\libraries\LCD12864R\LCD12864R.cpp:91: error: 'OUTPUT' was not declared in this scope
C:\Program Files (x86)\arduino-1.0.1\libraries\LCD12864R\LCD12864R.cpp:91: error: 'pinMode' was not declared in this scope
Im assuming the is due to an old library - can it be updated please - the analog pins was handy for a project I have.
