help with bluetooth bee
Hello there,
I really like the dfrobot bluetooth bee it works very well but I am having a problem. I connected the bluetooth bee to the fio v3 now I am trying to enter at mode but it never works. Do you know what the steps are to follow? I tried some stuff and in the serial monitor it wrote in there "ERROR: (0): do you know what this means? thank you
2013-01-04 19:04:46 Hi Transimissionline:
Thanks for pointing out. We've updated our wiki page with the latest info.
Really appreciated.
Best
Ricky R2D2C3PO
Really appreciated.
Best
Ricky R2D2C3PO
2013-01-01 20:15:31 okay for anyone wondering i figured out the problem the wiki here is outdated and incorrect : [url=http://www.dfrobot.com/wiki/index.php?title=BLUETOOH_BEE_(SKU:TEL0023)]http://www.dfrobot.com/wiki/index.php?title=BLUETOOH_BEE_(SKU:TEL0023)[/url]
you are not supposed to do AT+BAUD and change the rate you are supposed to do AT+UART=
look at the datasheet for the correct commands here
[url=http://www.dfrobot.com/image/data/TEL0026/TEL0026_Datasheet.pdf]http://www.dfrobot.com/image/data/TEL0026/TEL0026_Datasheet.pdf[/url] transmissionline
2013-01-01 09:28:56 Okay I got it working when I write AT it returns OK, but the problem is I cannot change name or baud rate those return ERROR (0) any idea of what the problem is? is there a special sketch i should upload to the arduino for this? transmissionline
