Forum >GPS/GPRS/GSM Shield 3.0
userHead Account cancelled 2013-02-20 01:00:34 3250 Views2 Replies
Hello
I have got this board. I follow the wiki and when I try to open port com. The led STAT turn off. I try to send AT command but nothing. I read that STAT led show if the SIM908 not run.
Any idea?
Max
2013-05-16 12:53:11 Hmm, is the Red PWR LED on? As well after you uploaded the sketch from Arduino you hit the RST button right?
I know my serial monitor will not work properly unless I:
1) Upload the sketch properly
2) Open Arduino Serial monitor
3) Press RST on the board
I also noticed that sometimes I have to have the 3 wat switch (UART Select) in the GSM or GPS side if i am USB mode instead of Arduino. But I'd try playing around with the 3 way switch to see if that is the problem as well.
Hope you get things going! :D
userHeadPic csmith04
2013-05-06 01:19:32 try to use an external power supply, I think it will work :) userHeadPic alnath
